Re: Fiberglass shower base rubber seal
Posted by Terry Love on July 09, 19100 at 14:21:48:
In response to Re: Fiberglass shower base rubber seal
: I Am installing a used shower base in my basement. The installation seems pretty straight forward. The base has a rubber collar which slides directly over 2" PVC.
: My question is if there is a sealant or lubricant I should put on the rubber collar to make the installation easier and more water tight or will this just cause problems.
: Also should the top of the PVC be sealed to the rubber collar after the installation
Soap can be used on the rubber seal. That's all you need. Terry
Replies to this post
There are none.
