| Posted by Rich on July 09, 19100 at 09:52:41: | |
I Am installing a used shower base in my basement. The installation seems pretty straight forward. The base has a rubber collar which slides directly over 2" PVC. My question is if there is a sealant or lubricant I should put on the rubber collar to make the installation easier and more water tight or will this just cause problems. Also should the top of the PVC be sealed to the rubber collar after the installation |
