Re: Hot water heater "knocks" with running water
Posted by murphyplumbing.com on July 09, 19100 at 00:22:24:
In response to Re: Hot water heater "knocks" with running water
: Murphy you should be more careful in making those assumptions. It's not necesarily build up and it could be dangerous situation. my advice is not an assumption though I would suggest having it checked out by a licensed plumber to verify the fact. : : : I just moved into a new home, and the hot water heater periodically "knocks" while the water is running. It is very loud and I can hear it in other rooms. This is an older gas heater from Sears (40 gal I think) and that's all I know. Is it about to die on me or is it something like air in the tank? Thanks!
: : : Bryan : : : : your water heater has mineral build up in the bottom. It is not a dangerous condition. sometimes draining it can help but not very often. invest in a new water heater if it is that old, it may be worth the peace and quiet.
Replies to this post
There are none. |
