| Posted by plmrdude on July 06, 19100 at 20:29:32: | |
| In response to Re: plumbing works in my toilet | |
There could be a number of things wrong. Is there a kink in your supply tube? (the hose under the tank). It may also be that your flapper isn't closing, and water keeps pouring into the bowl. If this is the case, check to see if the chain is too tight to allow the flapper to close; you always want a little bit of slack. If after all this, the problem is still not solved, go to the hardware store and get a new flapper. They're cheap, and very easy to install. Hope this helps. Plmrdude
| There are none. |
