Re: Connect plastic drain pipe to old cast iron
Posted by DeDe on July 06, 19100 at 10:37:47:
In response to Re: Connect plastic drain pipe to old cast iron
Terry, This is my luck day to have found your website.... I am tearing out a mosaic tile bathroom floor on a concrete wetbed(very time consuming,but coming along fine).What is the easiest way to connect PVC to the cast iron sewer line ? Also, can lead drains be repaired,I have a slight leak under bathtub. Thanks for your time. : I,m disconnecting old cast iron pipes to enlarge a small bathroom built over a concrete slab (about 6 inches : : between the slab and floor joists). What is the best way to unsolder the lead joints in the iron pipe? : : A small propane torch doesn't heat up the mass nearly enough to melt the lead and loosen the joint. : : Do I need to get a oxy/acetylene cutting torch to be able to apply enough heat? Also is there any way : : to wick the lead out of the joint once it is melted? Then what is the best way to connect the plastic : : piping to the remaining waste line that runs underground to the street? Any tips are greatly appreciated.
: Rebecca, : You may want to try cutting the lead with a sawzall. The blade can reach in and cut some of the lead out, and then screwdrivers can pry the rest out. Darn, there I am giving away secrets again. Please don't tell anyone else, OK? : Terry
Replies to this post
There are none. |
