| Posted by Dave on July 05, 19100 at 10:45:35: | |
In the past year my toilet won't flush unless you hold the handle down. I replaced the flapper but that didn't help at all. Recently, when you push the handle down, small air bubbles come up through the bowl. I suspect either the vent is plugged or something is blocking the drain. Any suggestions on what I should check first? |
| There are none. |
