| Posted by Scott Bryan on July 01, 19100 at 08:23:12: | |
| In response to Re: Tub Drain - Adjustment needed | |
![]() : A trickle of water is getting past the tub drain when it is closed. Is there a way to tighten the valve used to open and close the drain so the seal is tight? Jay, It's hard to tell how to make the adjustment without knowing what brand of bath waste you have. Some bath wastes use a washer or "o" ring to seal the drain plug, others use a brass plunger in the overflow tube to block the drain. Good luck, |
