Chlorine bowl cleaning tablets and your toilet
Posted by Terry Love on June 30, 19100 at 01:55:40:
 Have you ever wondered what happens to copper drain lines when you use chlorine bowl cleaning products? The picture above should scare you. The picture shows a three inch copper DWV pipe removed from a closet bend. Needless to say it was a pretty bad leak. I've seen this on commercial bar sinks also. Replacing copper DWV with plastic pipes is the best solution on them, unless it's a fire rated building in which case cast iron may be needed. On them, it's the combination of limes and lemons I believe. Terry
