| Posted by Terry Love on June 26, 19100 at 13:17:00: | |
| In response to Re: Can I/Should I increase main supply line size from well | |
![]() : I think my house has enough fixtures that indicates I could use 1" supply rather than 3/4". If someone could post or point me to the table where I can verify this it would be good. I need a larger pressure tank for the system. Can I increase my main from 3/4" to 1" when I change the tank without changing my pump? You can always make the pipes larger. Friction loss hampers water volumn. Sizing the pipes bigger helps. |
| There are none. |
