Re: Low water pressure
Posted by stew mcclelland on June 25, 19100 at 21:53:03:
In response to Re: Low water pressure
: Hi Joel,
: : I just moved into a house with a well. The house was built in
: : 1968. The tank appears to be a new tank. The water pressure
: : in the house is weak. What could cause this and what do I
: : need to do to find out how to fix it without paying someone
: : bunches of money just to diagnose the problem?
: Low water pressure could be:
: The best this system has ever had.
: Some possible reasons:
: Deep well and under sized/powered pump,
: Inadequate electrical service to pump(not real likely,
: the pump probably wouldn't last long if this were so),
: Very long pipe runs,
: Too small pipe,
: Switch set for low pressure, defective switch.
: Over time, pipes could be corroding internally and restricting flow.
: The pump could be worn out.
: Is there a spigot near the well that you can turn on?
: This will let you know if all is well at that point.
: My low water pressure is caused by distance from well. Where do I get a pump to install at house to boost pressure?
Replies to this post
There are none.
