| Posted by Ian on June 24, 19100 at 18:53:53: | |
| In response to Re: Dishwasher Vent | |
Advice I've gotten elsewhere has led me to this solution. I will take the drain hose, run it up as high as possible under the counter, attach it, then bring it back down into the drain. By taking the drain pipe higher than any of the other plumbing in the dishwasher, the same effect should be achieved and there will be no leaking. : >heck, i get mad when the wife turns the opening >to the back of the sink so if it does leak water >can go onto the counter! : You've got to stop treating your wife like that and mellow out
| There are none. |
