| Posted by dick on June 22, 19100 at 09:48:21: | |
| In response to Re: bath tub pipe replacement | |
: Beyand my tub spout..I have removed the nipples and elbow pipes that connect my water supply pipe. I broke off one nipple and some threading is stuck inside a pipe...i need to get it removed. How do I do this?? I'll assume you are talking about galvanized steel pipe. It's generaly not practical to remove the broken off thread. Just remove the next fitting. If your plumbing has deteriorated to the point where you are breaking off the pipes, you need to start getting estimates on a complete replumbing. |
| There are none. |
