| Posted by Terry Love on September 03, 1998 at 01:24:41: | |
| In response to Re: sewer hookup | |
ABS fittings can be used between the cast iron pipe and the clay pipe. You will need to locate proper couplings to go between the different size material. There are two thicknesses of cast iron pipe, and ABS is a little larger the large cast iron. Clay to ABS can be found also. Terry |
| There are none. |
