| Posted by hj on June 22, 19100 at 09:11:22: | |
| In response to Re: Dishwasher installation | |
The only thing that would affect the DW's pump is if it had to pump higher than normal which is not your situation. If you keep the hose low until it reaches the sink area, ideally under the cabinets, then the water in the hose will not drain back into the dishwasher when the discharge check valve eventually starts to leak. : I would like to put a dishwasher in the kitchen, but am unsure about the plumbing. The location is "around" a corner cabinet from the sink. IE. there is a corner cabinet between the sink and the dishwasher. I am unsure about how to plumb the drain. I have put a dishwasher in before, but simply tied it to the disposer drain. Here that would be difficult. I have an open basement below, with room, a hot water line and power, and need to know if anyone has a solution the the drain line and if I need a vent of some kind? I guess my concern is not tying into the drain, but rather, keeping the drain on the downhill side. I am wondering if the pump from the DW would push the waste uphill to the existing disposer drain a few feet away?? Any help appreciated. Please copy response to jmarro@mn.mediaone.net as well if possible. Thanks-Joe
