I havent had much experience with the cadet, but the Wellworth doesn't have a very powerful flush, and that's with the round bowl. It's a nice looking toilet, but needs a better flush. If you go with a wellworth, you might think about changing the flush valve/flapper unit , and install a normal flush valve that's designed for older toilets, then you should get a good flush. If you do go with another toilet, DON'T get a Mansfield Alto #160. The flush is lousy, and the parts it comes with are ultra cheap plastic. Good luck on your toilet hunt.
