| Posted by hj on June 21, 19100 at 09:32:47: | |
| In response to Re: gas line | |
You cannot use plastic for gas piping above the ground, and if you are referring to PVC then you cannot use it underground either. The only material a do-it-yourselfer can use is steel. : can you use plastic for gas to a dryer or does it it have to be steel?
