| Posted by Terry Love on September 01, 1998 at 21:07:25: | |
| In response to Re: Low water pressure after moving pipe | |
Anytime the water is shut off and turned back on, clogging can occur. Galv pipes are especially bad at this. ( you mentioned a section of copper ) Remove the aerators from the faucets, inspect and clean. The fill valve on the toilet can be taken apart and cleaned also. Terry |
| There are none. |
