Re: PVC drain- How hot?
Posted by hj on June 19, 19100 at 09:22:01:
In response to Re: PVC drain- How hot?
Unless the water is running through it constantly, then it will be okay for intermittent flow. Also water flowing through a drain is mixing with air that moderates the temperature.
: I have read that you cannot use PVC for hot water service. My question is- why is it ok to use it for DWV if it comes in contact with the same temperature water that comes from the "hot" side of a faucet (when no cold water is mixed in.)?
Replies to this post
There are none.
