| Posted by hj on June 15, 19100 at 01:45:22: | |
| In response to Re: removal/fix single shower faucet | |
from your description, I would assume it is a Moen faucet. Removing the stem may be easy, but more likely you will need a special pulling tool. You will be better off having a plumber change the stem, since you could damage the valve in the wall and then require an entirely new valve. : Terry, : I have a single valve faucet in a shower stall in my basement. I dont know how old it is or the brand. : One... what can I do to free up the mechanism. : Two..If it wont free up. How do I replace the valve. I have replaced other type faucets and valves before but : Thanks : Larry
| There are none. |
