| Posted by Terry Love on June 14, 19100 at 21:05:47: | |
| In response to Re: pipe material for irrigation system | |
![]() : I live in SE Michigan and am installing a lawn irrigation system. The house is copper-piped with 3/4 water service. I'd like to tap into the main line after the meter and use (C)PVC to two outside banks of backflow-equipped valves. I'm inclined to use plastic because I trust the glue joints over my ability to perform leakless soldering. Any suggestions on material to use are welcomed. Areas in question are: I would go ahead with the pipe off of the water meter, using a backflow preventer. PVC pipe will work fine. Below is the Hunter booklet for designing residential irrigation systems. Proper sizing is important. Terry |
| There are none. |
