| Posted by Terry Love on June 14, 19100 at 20:55:16: | |
| In response to Re: water heater not heating | |
![]() : my pipes started sputtering a couple days ago and now i have very little hot water. is there a connection? what can i do? if i replace the elements without knowing why, will they just burn out again? It could be a thermostat. You will need to check the thermostat resets and see if they need resetting. If they do need resetting, there may be other problems. It is best to test the elements before replacing them to determine where the problem really is. If you have some hot water, then the problem would be on the lower end of the tank. An upper element or thermostat would kill all power to the tank. |
| There are none. |
