Re: toilet-offset flange
Posted by c gioia on June 12, 19100 at 13:56:01:
In response to Re: toilet-offset flange
: : : For about 2 weeks now i have had a problem with my toilet because of the offset flange.The toilet keeps backing up because of toilet paper not going down.I've been in my house for 13 years, and i've never had this to happen.The plumber keeps coming out to work on it but hasn't solved the problem. I'm told that there is not much that can be done. He mentioned that maybe we can move the toilet over, but i have ceramic tile and i know that will all be broken, and i'm not sure how far it can be moved over because it may be too close to the tub. Any suggestions? I'm very stressed out about this. Your prompt reply is appreciated.
: : You do not say if the offset is used to make it a 12" rough or if it was installed to make it go left or right. They do make toilets that will fit a 10" rough (from back wall to center.) Ask your plumber if a power flush will fit on this rough-in.Dale's Plumbing Service Inc. LMP
The offset was installed to make it go left. I understand that it's more than 2 inches off. I can't move it over to the left because the tub is right next to it. The only other option i have is to go underground and install a new one. I know this is very expensive but i don't think i have a choice, at least it seems that way...What are your opinions on this..Thanks
Replies to this post
There are none.
