| Posted by Marty on June 10, 19100 at 13:36:36: | |
| In response to Re: Pressure balance / price pfister retro-fit ????? | |
I'm not sure what you mean by a 3 valve divertor, but if you're asking if a Price pfister, non-pressure valve can be replaced with a Price Pfister pressure balanced valve by simply replacing the catridges, I'd say no it's not possible. If you have access from behind the existing vavle, you can do the changeover without disturbing the tilework. Both pressure balanced and non pressure balanced valves use the finishing trim that are the same size. Hope this helps. Marty : Is there a pressure balance faucet out there that is built to match the p/p 3 valve diverter, to allow a fast replacement with no tile work ?
