Re: Are there alternatives for the wax seal?
Posted by John f on June 09, 19100 at 20:37:59:
In response to Re: Are there alternatives for the wax seal?
: Are there any other type toilet seals that can be used in place of the wax seal? If not what is the best type wax seal? I have seen a rubber gasket fitting that seals to the toilet flange and the i.d of the drain line, and I worked at a company established in 1911 that liked to use putty to build a ring. My opinion is that a wax ring with a plastic flange built into it is the best way to go.
Replies to this post
There are none. |
