| Posted by hj on June 09, 19100 at 09:46:29: | |
| In response to Re: PVC Drain Connections defined | |
The use of each fitting is intuitive. essentially, fittings that will have water going through them have to have sweeping turns. Vent pipes can use any fitting the fits. Using these two restrictions, and some local variations, if the fitting will fit, it will work. : : Is there a book or web site that illustrates the situations where each of the different types of PVC drain fittings are used. There are so many different types of fittings that seemingly perform similar fuctions that I need help. My idea of help would be a picture of the fitting and an illustration of it's use in a drain situation.
| There are none. |
