Re: Water Heater Problem Sears Kenmore Power Miser 10
Posted by Terry Love on June 08, 19100 at 12:26:31:
In response to Re: Water Heater Problem Sears Kenmore Power Miser 10
 : My water heater will only heat/come on when control is : rotated full CCW (the highest setting). The heater : worked perfectly until recently when it was set back to : vacation setting (low) and then returned to a normal : (hot)setting. : In other words, the sensing mechanism does not sense : that the water in the heater needs to be heated and : therefore it does not cause the heater to fire up. What : portion of the operating control has failed : and can it be replaced? Sounds like a thermostat. It can be replaced. Terry
Replies to this post
There are none. |
