Re: basement toilet overflow
Posted by Terry Love on June 08, 19100 at 12:22:51:
In response to Re: basement toilet overflow
 : We have a basement level toilet that periodically overflows (depending on what the waste is, of course). : It was snaked by a professional, however, it seems nothing substantial was dislodged. : The problem continued. A different toilet on the same level whose drain is upstream of the overflowing : toilet's drain (in the in-law unit) has never shown the same problem. Plunging will occasionally cause : sewage to back-up into the shower drain in the same bathroom. After plunging, it will operate normally : again for some days until the entire process repeats. We have been advised that a new toilet may : solve the problem. We have tried two different toilets, both of which could be described as low quality, : bargain units. Suggestions? Thanks, : -Tim Tim, Good toilets are a help, but the sewage backing into the shower is not a good sign. That sounds more like a main drain problem. A common problem with toilets is stuff hanging up at the lower part of the trapway of the toilet. You can see from the picture, that it goes flat for a while, and sometimes there is a bit of a rough lip around the exit that will catch all matter of toys, bottles and pens. Terry
Replies to this post
There are none. |
