Re: Water backing up! Is it cosmic?
Posted by Mad Plumber on June 08, 19100 at 12:06:52:
In response to Re: Water backing up! Is it cosmic?
: I am having a problem with water backing up. Whenever the tub is drained it backs up into the sink and when the sink is drained it backs up in the tub? What can I do the fix this?
Julia,
It sounds like the two are connected at some soul level. Perhaps in some cosmic way they mutually benefit from the same drain pipe. Their kinship and responsiveness to each others troubles indicate this.
I would try to acquire a long metal snakey thing to loosen, scour and pull from the troubled drains any vestige of hair and gunk you can find, and perhaps in some way, you can lessen the burden on these two plumbing fixtures. Mad Plumber
Replies to this post
There are none.
