| Posted by Tina on June 06, 19100 at 11:12:09: | |
From time to time I lose water pressure throughout the house. So far this has always happened in the when showering in the morning. The water runs for a while then loses pressure and stops. (I have a private well with a precharged storage tank.) When I check the water pressure gauge (when having problems), it drops but the pump doesn't kick on. There is no pressure for a while, then after 10 to 15 minutes, the pump kicks on and builds pressure back up and things work well the rest of the day and is ok for a couple of days. Originally I thought it was a bad pressure switch so I replaced it. Even though there is a new switch I noticed that the contact points on the pressure switch are closed at the time when there is no water pressure- but the pump doesn't kick on(or at least doesn't build pressure). I have also noticed that when the pump is working and achieves the set pressure that the contact points don't open up. I can then "kick" it off manually and the pressure stays/holds until there is water use. We have a water softner with a chorine injection tank tied in- if thats relevant?? Any thoughts or ideas would be appreciated. Thanks. |
