Leaky WEIL-MCLAIN boiler
Posted by Tom Simmons on June 03, 19100 at 10:03:04:
I have a Weil-Mclain VHE boiler with a leak into the pan below the burners. I have removed the side
panels and found that the area between the cast iron heat exchanger and the combustion area is wet.
If I disassemble the heat exchanger what material can I reseal it with?
Replies to this post
There are none.
