Re: Best procedure to level a bathroom floor
Posted by Terry Love on June 02, 19100 at 00:28:13:
In response to Re: Best procedure to level a bathroom floor
: I'm in the middle of remodeling a bathroom and the floor is way out of level (about 3/4"+ over 5'). I've removed the sink, toilet and old floor tile and wish to level the floor before i install new floor tile, etc.
: My first thought is to pull up the underlayment, leave the sub-floor, shim up the low side and use a 3/4" plywood for the new underlayment. The question is, at some point where the shim ends, there will be an air gap under the plywood, which I'm concerned may sag over time. Is there a product I can use to either fill that gap or level the floor.
: Am I way off base? What is the best method of leveling a floor? (if it's important the room is 5' x 10') Rick
Rick,
3/4 plywood can be centered on 16" centers for the shims. For final leveling, you can fixall for vinyl or use quick set for tile.
Replies to this post
There are none.
