| Posted by murphyplumbing on May 31, 19100 at 00:01:07: | |
| In response to Re: Tub Drain | |
: I have a tub that when you lift the lift the drain leaver to close and hold water it does not hold the water. : How do i fix ? remove the two screws from the plate, pull the entire assembly out of the drain. you will see that you will have a very long threaded piece down below. you will need to adjust the height by loosening this threaded piece so that is covers the drain and stops the water. |
