Re: Fiberglass shower/tub install
Posted by Terry Love on August 20, 1998 at 23:37:39:
In response to Re: Fiberglass shower/tub install
A fiberglass tub or shower enclosure is installed next to the stud wall framing. The finish drywall will go over a nailing flange which can be nailed or screwed in place. It is important to have a level handy to check the front edge of the shower for vertical alignment. Plywood should be under the stall attached to the floor joists. The vinyl floor underlayment can be installed after the shower is in place. Terry
Replies to this post
There are none. |
