Re: Glazed trapway
Posted by hj on May 28, 19100 at 17:05:55:
In response to Re: Glazed trapway
The advantage of a glazed surface is that it will not absorb stains. Once the surface is beyond viewing, glazing has little benefit. If the surface is not smooth to begin with then you will have a rough glazed finish, since glazing only coats the existing surface. It does not build it up.
: A selling point of toilets is that they have a fully glazed trapway. I just purchased a Kohler Wellworth
: elongated and found that the top of the trapway at the exit is not glazed. Is this standard for all "fully
: glazed" trapways?
: My assumption is that the benefits of full glazing are present only when there is no
: rough surface anywhere in the trapway to slow the progress of waste materials. Am I assuming too
: much?
Replies to this post
