| Posted by hj on May 27, 19100 at 10:42:20: | |
| In response to Re: Smelly drains / no venting? | |
The term for the device you are looking for is Air Admittance Valve. It allows air in to break a siphon, but keeps the odors from entering the room. If a sewer backs up, a fixture without a vent can get air bound and not drain. The AAV will also have this problem. : This might seem a bit weird to most people reading this, but drain vents don's seem to be used where I live (Spain). As you might expect, this seems to create a siphon effect in the drains - I think the water is sometimes being sucked out of the traps. Is there something like an anti-siphon valve that can be added neer the traps most affected? : The problem seems to be most pronounced around the toilet and especially after taking a shower. : Thanks much, : Greg.
| There are none. |
