Sewage Ejector Pumps
Many homeowners have questions regarding the installation of plumbing in the ground floor or basement of a home that is lower than the house sewer. Below are some solutions for the below grade floor.  Shopping
Zoeller Qwik Jon
Either floor mounted
or recessed flush with floor.
The Qwik Jon Breaks the Laws of Gravity . . .
Now with the Qwik Jon, water and sewage waste can go uphill, which means you can install a bathroom almost anywhere! The Qwik Jon pumps in any direction, is very quiet, and is leak-proof and odorless. Tank and all piping can be hidden. The Qwik Jon can be installed free-standing on any solid level surface, or the tank and all piping can be hidden behind a wall and under a 2" x 6" subfloor. No one need ever know it's there. The Qwik Jon is tough, sturdy and designed to be built in.
  • Qwik Jon tank, lid & gasket.
  • 2" solids-handling Zoeller-built pump.
  • Floor Flange Extender Kit with wax rings.
  • Check-valve.
  • Discharge pipe to lid.
  • Qwik Jon fittings and hardware.
  • Step-by-step Installation Instructions.
  • Engineering and Tech Data
  • pdf instructions
Pump sizing instructions
Model #100 Quik Jon,  $869.00
Toilet & lav
Model #102 Quik Jon,  $949.00
Toilet,  lav, shower
Little Giant
A floor recessed basin
  • Sewage Ejector Package System
    (piping not included)
  • 18"x30" molded polyethylene basin
    Single piece cover (2" vertical discharge)
    Snap-in vinyl hub and a 2" check valve
  • Includes pump #509500/9S-CIA-RFS
    Includes a non-mercury remote float switch
    On level 9"-14" of water
    Off level 2"-6" of water
    Handles up to 2" semi-solids
    Shut off is 18" foot
    2" discharge
    15 foot power cord
    4/10 HP, 80 GPM
                specs
Little Giant #5090259S-SMPX-B,
$379.99
The threaded hole is used for the vent. The non-threaded hole is used for the discharge line.
High water alarms
101WH...$91.00 plus shipping
HW-9...$24.00 plus shipping
Little Giant Sewage Sizer
To purchase a Saniflo system
The Saniplus is a system that is used to install a complete bathroom up to 12 feet below the sewer line, or even up to 150 feet away from a soil stack
The Saniplus is simplicity itself to install; there are just four connections.
  • The macerating/pump is connected to the spigot of a horizontal outlet toilet.
  • The toilet tank is connected to the water supply.
  • The macerating/pump is connected to the small diameter discharge pipe work.
  • The macerating/pump is connected to the electrical supply.
Saniplus information
Description
Retail List prices*
Prices current as of Jan 15, 2001
Saniplus c/w toilet
$995.00
Sanicompact
$708.00
Sanimarin
$708.00
Sanivite
$349.00
Sanishower $274.39
Sanipack $422.35
Sanibest $620.00
Sanistar $949.36
Saniplus only $569.39
Sanipro only $513.74
Toilet Complete $222.20
To place an order | to our FAQ page | to our home page
