Installation of softener with well
Larry_T
Hi -
Two questions regarding installation of a softener with a private well:
1) We have slight sediment in the water after hard rains. We were going to install a whole house filter at the same time as installing softener, but reading posts here do I understand correctly that a whole house filter is not recommended if we install a softener?
2) The way the utility room is set up in our basement, it looks like space for a softener is _before_ the pressure tank. Is this the correct location? Somehow, it seems that the softener would be after the pressure tank.
Thanks.
Giles
We have a drilled well, about 300'.
Sometimes, a day or two after heavy rains, we'll notice a slight discoloration of the water in the toilet bowl or bathtub. By slight, I mean you can just barely tell that the water isn't perfectly clear. It clears up within a day or two.
Hi -
Thanks.
Giles
Giles, have you had the water tested? Just wondering why you think you need a softener.
Back
