Solar water heater
dpowell126
I'm building my own solar water heater I need some technical advise.
1. I will be using roof top solar panels and will need to convey the heat to the basement for storage. Is there a more cost effective 1/2" material than copper that will withstand the temperatures (200 degrees or more)
2. What is the best insulation for the pipes
3. The design includes a heat exchanger that will involve a concrete slab with the hot water running through ir. I I use copper, will it hold up and not corrode in the concrete? I need it to withstand the temperatures and transfer heat easily. Will Pex work?
Concrete and copper aren't all that great together. Pex can't handle that high of a temp, at least at higher pressures...it might work since your pressure would likely be fairly low. It gets derated as the temp goes up for the amount of pressure it can handle.
need more informatoin
Their are a lot of different systems out there...
It really depends on which type you are installing...
Will the panels have water or antifreeze or oil going through them???
The oil type are the best...from what I remember...Like the NOVAN style from the early 80s..
Wirsbo pex for radiant heating under the concrete floor
would be good..
probably best to reveal more information or links to what you are considering doing...
these systems are a little complicated and can be a pain if you are not capable of tinkering with them yourself...
and some are much better than others..
post a link to what you are looking to install...
One thing people forget is that the higher the water temperature, the lower amount of heat you get since the system radiates heat back out of the panel.
This means that it is best to increase the pump speed so that the water temperature is more even and as low as possible.
FYI: The light concentrating unit we are designing reached 400F with an outdoor temp of -10F during a "dry" test a few weeks ago. However this still means that we have to run the water at a much lower temperature to capture as much heat as possible.
A 250' roll of K copper, unrolled on a sun exposed roof, painted flat black, with an adjustable speed recirculating pump, will work well in a non freezing area.
You might be able to hook it into your still and pre heat the mash also...:D
Whats a 250' roll go for these days? Copper prices seem to be down at least for electric wire
I'd like to build a heater for warmer weather use
But it would be connected before the electric water heater - as a pre-heater. If it gets too hot wouldn't that cause a pressure problem in the tank?
A different recirc system in the same structure (with glass panels) would be used to heat the pool. So I would have a means of keeping the temperature down
solar
The solar pump or circulation is controlled by the water heater, AND the temperature diffential between the coil and the tank. If the tanks temperature setting is satisfied the water in the coil will be heated to whatever temperature the sun can heat it too, so you cannot depend on it ALWAYS being below the safe level for PEX or anything else other than copper. If you just put a coil of black copper on the roof, you have absolutely no control over what the temperature in the tank will be. AND it is very common for even a controlled solar system to trip the reset hi-limit on the upper thermostat. Black finned copper is the only material that will give a rapid response to changes in the solar radiation.
The water coming out of my pool solar hot water heater tops 130 when it is 1st turned on. It quickly drops to about 95
On camping trips we took solar hot water bags, quite often they were too hot
My dad always heated the pool with a 500' roll of black plastic well pipe thrown on the ground and piped through the filter. Worked great. Looked like crap for a few weeks.:D
Back
