Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Electrical Forum discussions
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 11-06-2009, 08:07 AM
JeffGr JeffGr is offline
DIY Junior Member
Default Sub Pump wiring
Currently I have a well 375' from the house. It is supplied via it's own meter from the elect. co. The entire electrical system is about to be condemmed. The overheads run through trees etc. I also need to replace the piping from the pump to the house.
Getting rid of the meter will save me $180 per year in facility fees.
The pump is a 1/2hp 110v. I plan on replacing it with a 220V 3/4 hp next summer.
I need to install the new piping now so plan on running new electrical wiring now as well, while I have the trencher. So the pump will run off the house's electrical service eliminating all other wiring to the pump. I have a new 200 amp service at the house.
With a 3/4hp 220v pump I can use #12 as it goes 480'. I will use a breaker box at the pump as well as a disconnect.
Is there any economical options to use the existing pump on the new wiring? It is too long a run for 110v using #12. I would have to go #6 but the price is out of sight.
I will be using UF cable and burying it 36" down. What is the proper way to permanently splice underground? Can I use crimp sleeves and epoxy filled heat shrink? Or do I have to try and find one run of wire? I'm rural so don't have the options of the big city.
  #2
Old 11-06-2009, 11:55 AM
Spaceman Spiff's Avatar
Spaceman Spiff Spaceman Spiff is offline
DIY Senior Member
Looks like you need a #6 wire for the distance and voltage drop, not to mention the drop of cable down the well pipe.
I would run 1-1/4" PVC conduit 36" underground next to the water pipe and pull in #6 THWN conductors. Then you don't have to worry about code violations regarding depth. I'd look up the burial depth but my code book is at home...
__________________
Spaceman Spiff aka Mike
  #3
Old 11-06-2009, 05:20 PM
220/221's Avatar
220/221 220/221 is offline
Do NOT run 400' of UF cable. You are asking for trouble.
Install 1" PVC (about $200) and #6 wire minimum.
http://www.electrician2.com/calculat...r_initial.html
Do NOT make splices underground. Again, that's just asking for trouble.
Install this circuit properly and it will work for your grandkids. Cobble it together and you will hate your life.
  #4
Old 11-07-2009, 08:25 AM
Lakee911's Avatar
Lakee911 Lakee911 is offline
I&C Engineer (mostly WWTP)
Send a message via AIM to Lakee911
You may want to consider running Aluminum type XHHW wire in PVC conduit. That might be your cheapest option.
Jason
  #5
Old 11-14-2009, 07:36 PM
Ford2001 Ford2001 is offline
DIY Junior Member
Default voltage drop calculactor
To: 220/221
Me like the "Voltage Drop Calculactor" you posted.
Where its saids: "enter 1-way circuit length in feet"
Is it adding another 100 feet, if the one-way circuit length
is 100 ft. ? I believe it would.
Thanks.
  #6
Old 11-15-2009, 07:39 AM
jar546's Avatar
jar546 jar546 is offline
Don't forget the ground the well casing
__________________
www.InspectPA.com/phpbb
My answers are based mostly on the ICC codes. Advice given is my personal opinion and every person performing work should acquire a permit from his/her jurisdiction and get the work inspected. My opinions are not directions to follow for DIYs or professionals
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
