Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Pump and Well Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 11-04-2009, 06:03 PM
brianjcollins brianjcollins is offline
DIY Junior Member
Default Bad Pressure Switch?
I'll try to explain this as best I can. I bought a house about 6 months ago and over that time i've had many plumbing issues, luckily mostly small. During the minor fixes I noticed that my pressure gauage was showing a high pressure around 95lbs, so in a pinch I called a plumber out to adjust it. After he left I took a shower and the water was cutting out really bad down to zero water flow. It turned out to be a bad pressure gauge. I used a guage hooked up to a hose to get me an idea of what pressure I had running and adjusted accordingly. That pretty much got me by. I did end up replacing the bad pressure gauge today and then re-adjusted the pump pressure switch to 40/60 with my well tank pressure are 38. I continued to test it a few times and the upper end of the gauge started growing, I started at 40/60 and now it go to about 40/68. I spun back the one nut to try to turn down the top cut-off, but the nut is so loose the spring isnt under any tension. My only other option is to turn down the large spring to adjust overall pressure and drop it below 40. Could that be a bad switch? The other thing I notice is when I simply run a bathroom faucet, the pressure drops over 2 minutes or so, the pump kicks on, runs the pressure up to it's top cut-off, and repeats aslong as the facuet is opened. Should that happen or should the pump simply maintain pressure and remain on while it's calling for water?
Sorry if that is written poorly.
Brian
  #2
Old 11-04-2009, 06:41 PM
Cass's Avatar
Cass Cass is offline
Moderator & Plumber
Well now that the pressure switch is all out of adjustment going out and buying a new one and replaceing it will be the easiest thing you can do...get one with a low pressure cut off...
__________________
The New Weekly Word
If guns cause crime, then pencils cause misspelled words.
What some of the moderators do from time to time
BOWDLERISE
To remove material that is considered improper or offensive.
http://www.avatarist.com/avatars/Various/Ball-game.gif
  #3
Old 11-04-2009, 06:42 PM
Teets Teets is online now
DIY Member
When you changed the pressure switch, did you check to make sure that the line that feeds it was free from any dirt or debris that might impede the pressure switch from operating properly. If you have a faucet that is letting out water at only 3 or 4 gpm and you have a pump that pushes more water than that, then your system will cycle like you are seeing.
  #4
Old 11-07-2009, 09:03 PM
DIY Junior Member
Well, I changed out the pressure switch to a factory set 40/60. I don't see much change, reads correctly and everything works.
I still have the issue, I seem to have decent flow, but must have a blockage somewhere in the system. If I have all the faucets, showers, etc running, the pump can still seem to build pressure faster then it uses it. If I use the closest spout off the well, that can pump water faster then pump can deliver it and it just stays on. I'm somewhat at a loss.
Tommorow I am going to get something that will allow me to test my faucets pressure. Is there a way to measure water flow, asside from the manual method of stop watch and bucket?
Brian
  #5
Old 11-08-2009, 05:32 AM
Peter Griffin's Avatar
Peter Griffin Peter Griffin is online now
Is the pump in the well?
__________________
I stayed at a Holiday Inn Express last night
Ignorance can be fixed. Stupid is forever
  #6
Old 11-08-2009, 06:27 AM
Cass's Avatar
Moderator & Plumber
Now don't go trying to adjust the set screws on the new switch...Have you checked the charge in the bladder tank?
You might want to try letting all the air out of the tank and see if there is any water in it...I have run into tanks that were 1/2 water logged...
__________________
The New Weekly Word
BOWDLERISE
  #7
Old 11-08-2009, 07:40 AM
DIY Junior Member
Heh... I am not touching the nuts on the new switch. I'm sure the factory settings are 100% correct. I've drained the tank and it shows about 38lbs, which should make it right.
It appears as though everything is working except for my low flow at faucets and the pump can outpace my faucets every time.
I'll be leaving it alone for a few days/weeks. I can wait to have someone who knows much more than I look at it.
Thanks everyone for your help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
