#1
I can't stand shower heads that don't put out enough water. So when the flow from my new shower head was weak, I drilled out the plastic flow restrictor. Now my shower rocks, but the water heater can't keep up. It's 10years old so I figure it's time to replace it anyway.
Question 1- If I replace the old 40 Gal gas water heater with a new 50 Gal(with better recovery), am I likely to still have the same problem? Question 2- Should I consider a tankless heater to resolve this problem? I know I should probably put the restrictor back in and live with a sissy shower just to save energy and water... |
#2
Quote:
Run the shower into a large bucket. Multiply the gallons collected by the length of time you take a shower. If you collected 2 gallons in 30 seconds in the bucket and you take a 10 minute shower [600 seconds] you need 2(600/30) = 40 gallons of water, probably half of which is cold water. Last edited by Thatguy; 11-04-2009 at 12:02 PM. |
#3
Not really enough info (how many people in the house, ect.)
1. Maybe, maybe not. A single person shouldn't run a full 40 gallon gas heater "dry" with one shower. 2. I wouldn't unless there were space issues.
__________________
Matt Semi-professional plumbing designer
#4
We are a family of three with two full baths. It would be great if we could all shower one after another. Now we stagger showers at least 20 minutes apart to let the water heater "catch up".
If I do the math for the shower- even with a 2.5 gpm shower head I would be out of hot water after 2 ten minute showers (or one average teenager shower). How much can the WH "replenish" it's hot water reserve while it's working? So wouldn't this be a reason to go tankless? I would prefer a good old fashioned tank since I don't want to incurr the expense for installation of tankless, but running out of hot water is irritating. |
#5
Rather than bore out the orifice, try to find a new showerhead with a spray pattern that actually does a good job at its rated flow. I paid something like $12 for a standard 2.5 gpm Peerless that I really liked. It was one with 5 settings. Many of the older 2.5 gpm showerheads were awful.
In a house that had a 5 gpm showerhead and an electric water heater we tended to pause some between showers because the water was beginning to cool after my wife's typical 15 minute shower. ![]() An inspector acquaintance likes his old WaterPik but is well aware of how quickly it runs out of water. He bucket tested it at 9 gpm!!!
#6
If you're thinking of tankless, take a look at some of the threads in that section. Cost is a big deal - sometimes involving upsizing gas service and the exhaust. Why not look at a tank type with a storage tank with a recirc line? Or a larger (80 maybe) gallon tank.
__________________
#7
Quote:
30 minutes @ 2.5 GPM @ 97F ideal shower temp = 75 gals, 2 gals out of 3 [50 gals] being 120F water and 1 out of 3 [25] being 50F water. Last edited by Thatguy; 11-04-2009 at 01:55 PM. |
#8
The spec sheets of any WH show first hour delivery in gallons. This is the number you want to compare.
__________________
Jim DeBruycker Important note - I'm not a pro FWIW - Don't try to buy a phone from Nokia on-line |
#9
Try turning up the heat (temp) on the heater...hotter water will give you longer under the shower time...
__________________
The New Weekly Word If guns cause crime, then pencils cause misspelled words. What some of the moderators do from time to time BOWDLERISE To remove material that is considered improper or offensive. http://www.avatarist.com/avatars/Various/Ball-game.gif |
#10
Thanks all. I'm leaning towards a new 50 gallon and will check the spec sheets and I'll add a washer to see if adjusting the flow a little helps.
#11
Domestic water heaters, unless you are prepared to spend a LOT of money, ALL have similar BTU inputs therefore the recoveries will be comparable, which means you will NOT get any more hot water of a new one than you get now. To get more water you need a LARGER water heater. Once you reach a certain size then the btu inputs become somewhat greater also.
#12
You may gain a quicker recovery with a new heater if you are in a hard water area and don't have a softner...the bottom of the heater will have a blanket of build up slowing the heat transfer...A new heater won't...for a while...but it will slowly build back up unless you get a softner...
__________________
#13
Quote:
And rather than try to maximize flow at the showerhead by boring the thing out or enlarging the system to commercial sizes, it makes far more sense to spend some money experiementing with showerheads until you find one that works well at a reasonable flow. The OP might want to find some reviews to find out which type of showerheads work best for the type of showers he prefers. Some folks like wide gentle spray, some like a forceful needle like spray that feels like acupuncture. Others want massaging shower heads or all of the above. For locally purchased showerheads, don't be bashful about taking one back if you don't like it. |
#14
Quote:
I've been through dozens of low flow showerheads and have yet to find one rated for 2.5 gallons that provided an adequate shower for my tastes. A simple drilling is a heck of a lot more convenient than replacing the showerhead multiple times and returning them. |
| Bookmarks |
| Thread Tools | Search this Thread |
| Display Modes | |
