What code are you using? UPC requires 2" for a toilet vent.
According to my hand book the minimum pipe size required to vent a toilet is:
1.5
Or
2 as a wet vent for a sink.
Am I understanding this correct?
Ok so I need at least a 2 vent for my toilet.
Can I also drain my sink into the same 2 pipe?
I still don't know what code you're using, or how you're going about it.
It really depends on your local in the USA
I get away with murder in INDIANA with our code....
1 1/2 pvc is big enough for the whole house to be
vented onhere....
other parts of the country expect a full
3 inch stack out hte roof..
With newer toilets that flush faster, you would want at least 2" on the vent.
In some places you can wet vent a bathroom lav over a toilet, if that line is 2" or larger.
A kitchen sink could not be wet vented.
The book I am reading is a general construction book it covers everything from grading to roofing. The book dose not tell me specifically what size vent I will need for a toilet; however, it dose have tables soused from: "UBC Illustrated training manual (Walnut, calif: International association of plumbing and mechanical Officials 1985)."
In one table I read that a private toilet counts for 4 fixture units. The next table shows 1.5" pipe being capable of venting 8 fixture units. Based on these two tables it appeared that 1.5" pipe could actually vent 2 toilets.
In the houses I have worked on I always see 2" vent pipes for toilets, add to that your reaction and the fact that I dont want to get into a challenge with my inspector, I am definitely not going to install a 1.5 vent on my toilet.
Thank you for the diagram Terry!
So It is ok to use a 2" pipe as a wet vent for a toilet and a bathroom lav. Would this setup be in compliance with: "UPC 2006"?In some places you can wet vent a bathroom lav over a toilet, if that line is 2" or larger.
It has been my experience that most cities in the LA basin don't make up plumbing codes; instead they simply adopt "UPC". But I will need to confirm it in my particular city.
I have the third edition of the code check plumbing for 2006, the little flip job books, it says the IRC does not require a vent on a water closet for residential. What's up with that?
