Zone Isolation
Discussion in 'Boiler Forum' started by essjay, Jun 5, 2013.
  1. essjay
    essjay New Member
    Nov 12, 2012
    Pennsylvania
    I have a hot water boiler (recently replaced) that provides both DHW and heating in 3 zones. The zones are by run by floor. The basement zone piping was run through the slab when the house was built (1965). Since the piping is approaching 50 years of underground contact I want to replace the piping run to above-ground (under the basement joists like the 1st and 2nd floors).
    I know my job would be easier with individual zone isolation, but am unsure if I COMPLETELY have that with the basement zone. I can see both a drain and isolation valve on the return, but am unsure as to whether I have or need an isolation valve on the source (see attached pics).
    PIC1: Shouldnt there be an isolation valve on the basement zone supply?
    PIC2
    PIC3 : I am also unsure of the extra drain bib on this line?
Similar Threads: Zone Isolation
Boiler Forum Adding basement zone to hydronic boiler / enclosing boiler Feb 5, 2017
Boiler Forum Adding a Zone to a Boiler Jan 9, 2017
Boiler Forum hydronic question on wiring a zone valve to shut off qravity feed to upstairs loop Jan 7, 2017
Boiler Forum How to test zone valves Feb 17, 2016
Boiler Forum Radiant floor heat zones very puzzling...any ideas? Feb 3, 2016
