Zoeller sump pump recall info
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by bubb1957, Mar 3, 2007.
  1. bubb1957
    bubb1957 New Member
    Jan 9, 2007
    Banker
    Northern Ohio
  2. sumppumppimp
    sumppumppimp New Member
    Sep 23, 2005
    The pumps are the 53, 57, 151, 152, 153, and the model 48. If any of these pumps that have the 20' cords and if that cord has "phillippines" stamped on the plug, then there could be a grounding problem with the ground pin! If the plug has been cut off and the pump is hard wired, then there is no problem! There was around 2600 pumps affected by this. The pumps were made between 09/06 and 10/06.
  4. Rancher
    Rancher Guest
    It's nice to have the manufacters watching the forums, thanks ZP!
    Rancher
  5. sumppumppimp
    Sep 23, 2005
    Appreciate it!:D
  6. carmel corn
    carmel corn New Member
    Oct 14, 2005
    Glad I saw this....was getting ready to pickup another M-53.
    ZP - curious...is the same source used for other cord lengths?
  7. sumppumppimp
    Sep 23, 2005
    If you are picking up the M-53 you will not have a problem with it! If you are picking up any pump right now, you are not going to have a problem with it! It was for only some ofthe pumps that were made September and October of 2006. This was for only about 2600 pumps of different models during that time, Zoeller actually produces about 26,000 "50" series pumps alone each month.
Similar Threads: Zoeller sump
Pumps and Tanks Well Forum & Blog. Water is life. no yellow light on zoeller battery backup for sump pump Oct 26, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Buying a new sump pump - Zoeller with aftermarket switch? Jun 28, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump - Zoeller? Nov 18, 2009
Pumps and Tanks Well Forum & Blog. Water is life. 3/16 " hole for Zoeller Sump Pumps -where? Apr 15, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Zoeller Sump Pump Question Jan 23, 2008
