Zoeller Sewage Pump switch doesn't always work
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cej22, Mar 18, 2009.
  1. cej22
    cej22 Member
    Mar 18, 2009
    Seattle, WA
    I'm having a hard time finding an answer by searching.
    I have a house that's about three years old and over the last few months the sewage pump has failed to turn on three times, causing minor flooding in the unfinished basement. When it fails, I can lightly kick the discharge pipe and the pump starts immediately. It's a green Zoeller pump, but I can't determine the model number. If I had to guess based on the shape of the top and the price point of the home, I would say it's probably an N57. It has a separate float switch, but I don't have the slightest idea how to determine what brand it is.
    Is it a fairly safe assumption that this is a problem with the switch? What would cause the switch to fail very occasionally? If so, is the answer to change it with the Rhombus VerticalMaster switch? Are these commonly found? I called the big plumbing supply place I've used before and they are not a distributor.
    I think I'll also install an alarm. Any recommendations?
    Any guidance here would be greatly appreciated. Thanks.
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Is this pump ejecting sewage from bath or is it for just ground water?
    Ii maybe that the float switch arm needs to be cleaned.
  4. cej22
    cej22 Member
    Mar 18, 2009
    Seattle, WA
    It is for sewage and the float switch is tethered.
  5. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Is this the pump? It`s an M57
  6. cej22
    cej22 Member
    Mar 18, 2009
    Seattle, WA
    I think it's the "N" version, which doesn't have the attached float.
  7. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer.. plumber of mens souls
    change the switch
    buy yourself a verticle master switch and just stand on your head in that pit and change out the bad switch...
    all you got to do it take a pair of wire cutters and cut away the switch... then attach the new switch to the pvc pipe and set it to the right height...
    remember ..... dont fall in...
    and dont cut the pump wire
    [​IMG]
  8. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    The only N57 is the oil smart system.Can you send a picture?
  9. cej22
    cej22 Member
    Mar 18, 2009
    Seattle, WA
  10. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    It is the basicly the same as the one I showed earlier.
    Get some rubber gloves and toggle the arm coming out of the side at the
    top several times to see if there is an obstruction.Un plug it first and
    toggle the switch the plug it back in and toggle while plugged in.
    Then run water to see how it operates.
  11. cej22
    cej22 Member
    Mar 18, 2009
    Seattle, WA
    Thanks for the advice. I replaced the switch with a Rhombus VerticalMaster and installed their indoor alarm, as well. Everything seems to be working fine.
    The bad float switch was a Zoeller that was only 4 years old and the pump gets very little use. Not very impressive.
    Mark, I managed to not cut the pump wire and not fall in. ;)
Similar Threads: Zoeller Sewage
Plumbing Forum, Professional & DIY Advice Zoeller ejector pump system noisy? Mar 6, 2017
Plumbing Forum, Professional & DIY Advice Superior pump vs Zoeller; Zoeller options Jan 19, 2017
Plumbing Forum, Professional & DIY Advice Replacing a backup Zoeller 507 with something higher in capacity? Jan 3, 2017
Plumbing Forum, Professional & DIY Advice Replacing a Hydromatic DA-1 10 with a Zoeller M98 or Liberty 287 Jan 3, 2017
Plumbing Forum, Professional & DIY Advice Converting Zoeller M53 To N53 Dec 26, 2015
