Qweth
Hi, I have recently had my well pump go out and when I replaced it, I finally got our pressure tank aired up and installed a check valve this time because I could hear the water siphoning back down the well, so.. I turned off the pump and drained as much water as I could out of the pressure tank, then put air in the valve up to ~36psi and now there is dirt coming in with my water, to where it leaves a thick layer sometimes, and I am wondering what I can do to clean it up.
oh yeah I had a bit of air in the tank for awhile and it was working quite well once I got the check valve in, but I assumed the pump would be clicking on/off too often still when water was running inside. Could all this be a result of not having totally emptied the pressure tank?
Advice would be appreciated very much.
