Yet another vent question....(sketch)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by SuperDaddy, Mar 25, 2008.
  1. SuperDaddy
    SuperDaddy New Member
    Mar 25, 2008
    New York
    Just wondering if it is possible to vent a toilet in this manner (see pic).
    4" waste with a 3" vent line coming off the back of the waste line.
    I'm not sure if this is acceptable or not. I am worried about the actual "waste" getting caught on the tee portion on the "way down".
    I searched, but couldn't find anything that dealt with this scenario.
    Any thoughts?
    [​IMG]
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Why don't you have the tee under the wall instead of the toilet and have a 90 going from under the toilet into the branch connection?
    Otherwise, if you are determined to use your current setup, you can swap out the tee for a wye fitting.
  4. BAPlumber
    BAPlumber Plumber
    Jul 18, 2007
    Journeyman Plumber, business owner
    Vashon, Washington
    this is a fairly common setup for older homes. the (barrell vent) usually is used with a 2" Vent (code), I've seen it with a 3/4" vent (not code). I don't see a problem with a 3" vent, but no advantages.
  5. hj
    vent
    You need a "Y" rather than a "T", but otherwise it is okay. Depending on the rest of the plumbing system, you may only need a 2" vent however
  6. SuperDaddy
    Mar 25, 2008
    New York
    Thanks for your help guys, I appreciate it.
  7. bombjay
    bombjay New Member
    Mar 11, 2008
    [​IMG]
    Hope this quick scribble helps.It shows a 4x3 toilet bend into a sanitary tee that is below your 3" vent
  8. SuperDaddy
    Mar 25, 2008
    New York
    Excellent. Thanks. I am still tossing around ideas.
    I appreciate the help.
Similar Threads: another vent
Plumbing Forum, Professional & DIY Advice How to add another vent? May 22, 2015
Plumbing Forum, Professional & DIY Advice Another toilet venting question Jul 14, 2014
Plumbing Forum, Professional & DIY Advice Another Toilet / Sink Vent Question Jan 13, 2014
Plumbing Forum, Professional & DIY Advice Another venting question Dec 10, 2009
Plumbing Forum, Professional & DIY Advice VENTING one GHT into another ? Nov 6, 2008
