Yet another bathtub drain problem
Discussion in 'Shower & Bathtub Forum & Blog' started by Jim Weisz, Sep 3, 2005.
  1. Jim Weisz
    Jim Weisz New Member
    Sep 3, 2005
    About once a week, my bathtub regurgitates enough water to cover 1/2 - 2/3 of the bottom of the tub. The water has black, flakey gunk which does not drain back. Other info:
    1) The tub in on the second floor.
    2) No other drain has this problem.
    3) I've lived here over 5 years, and the problem only started a couple of months ago.
    4) Using one of those cheap plastic clog removers helped with the speed of draining (which was a bit slow), but another regurgitation happened a couple of days later.
    What's up wit dat?
    Jim "A computer programmer, not a plumber" Weisz
  2. Cal
    Cal New Member
    May 10, 2005
    Northern Virginia
    Jim,
    "my bathtub regurgitates enough water to cover 1/2 - 2/3 of the bottom of the tub"
    Does it do it when not in use ?? It's the 2nd floor ? Are you in an apartment ? Need more info !
  4. Kristi
    Kristi Tradesman Plumber
    Jan 27, 2005
    Tradesman Plumber
    Vancouver, BC
    I'd personally get a drain "scrubbing" done... they'll blast the drains from bottom to top with detergent and water which will slough all the crud off the inside walls of the drainage line. bet your problem will disappear. snakes and such do a great job of clearing things up temporarily but tend to just bore a hole through the centre of the problem (if this indeed is your problem) - if you have decades of build up inside the pipe, then it's a good idea to get it cleared out. If you left it long enough, I'm sure you'd find the problem occurring elsewhere eventually. Lot's of other suggestions will be out there...!
  5. hj
    drain
    A proper sized snake will do more than bore through the center of the problem, and if the drain is plugged all the water that a jetter is using has to come back up somewhere, and if it does not unplug soon enough that "somewhere" may overflow. Tubs do not regurgitate water. It has to come from somewhere and until you know where that somewhere is there is no way for us, or anyone else, to tell you how to cure the problem. One certainty is that chemicals will not cure it.
  6. Jim Weisz
    Sep 3, 2005
    Yes - it does this when it's not in use. It had occurred several times until I happened to be home and caught it in the act. The tub is on the second floor of a townhouse.
    Thanks others.
  7. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    2nd floor bath
    HJ is right. You need to snake it out.
    I would go right in the tub overflow.
    Take the face plate, off-set it and bolt it back on with only one screw so that you can get the snake started down.
    That way you won't move the pipe or waste and overflow
    I use a RIGID electric drain cleaner with a 3/8" cable.
    Cable comes in 7-1/2' lengths.
    I don't put any thing on the lead end.
    I kink the lead piece of cable and that surely covers the whole inside of the drain .
    Besides you can run water while working and that both flushes the pipe and cleans the cable.
  8. Kristi
    Jan 27, 2005
    Tradesman Plumber
    Vancouver, BC
    But what would explain the tub backing up when it hasn't been in use and no one is home? the water must be backing up from somewhere else down the line...?
  9. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    bathtub
    Yes KRISTI, thats what I guess from this vantage point.
    Could be something in common with the adjoining townhouse?
    Snake it out...............
  10. Jim Weisz
    Sep 3, 2005
    That's what I'm wondering too. The sink, which I assume is on the same line, doesn't have the problem.
  11. Jim Weisz
    Sep 3, 2005
    Update: I got a snake and followed plumber1's directions (thanks for being explicit!). No amount of twisting or poking sufficed to get it in more than about 2 feet. There was no gunk present when I pulled it out and no apparent increase in drain speed.
    What's next? Should I just pop for a pro?
  12. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    drain
    Dont know what your snake looks like and may be I couldn't use the one you used either. You almost have to feel your way through the trap.
    I usually use my electric snake with 71/2' sections. 3/8" di.
    These little top snakes in a can are usually a waste of time.
    I don't know when the last time was that I couldn't clean a tub drain through the trap.
    Years ago 2nd floor p-traps were cast iron and had a brass c.o. plug.
    You had to gain entrance through the access door.
    Tub drains don't plug very often.
    Sounds like you have an unusual condition.
    I would like to be more helpful, sorry
  13. Jim Weisz
    Sep 3, 2005
    It's a 1/4" 15' snake (one with a tubular aluminum handle) I got at Menards.
    Too much for me - tomorrow I call for a pro.
    Thanks for your help - I appreciate it!
Similar Threads: another bathtub
Shower & Bathtub Forum & Blog (another) Seeking bathtub choice advice (thread) Jul 22, 2010
Shower & Bathtub Forum & Blog Yet Another Delta Monitor Question Aug 19, 2016
Shower & Bathtub Forum & Blog Another question...Shower Drain Jul 8, 2015
Shower & Bathtub Forum & Blog Another leveling the tub thread. May 6, 2015
Shower & Bathtub Forum & Blog Another "help ID this shower cartridge" (& where to get a replacement) Sep 25, 2014
