WTGO-4 Oil Boiler - Question
Discussion in 'Boiler Forum' started by DNYC, Jan 15, 2012.
  1. DNYC
    DNYC New Member
    Jan 15, 2012
    NYC
    I have an oil fired WMC WTGO-4 tankless boiler, which is being used for both heating and hot water. Howerver, there is a few min delay when the water heats up, which is uncomfortable especially during the winters. After doing some limiter research, my two options seem to be to either add an indirect fired tank or an on demand natural gas fired water heating system. Any suggestions? Also, if you can provide reliable brands that i can use to complement my heating system. Thank you.
  2. Gary in NJ
    Gary in NJ Member
    Apr 11, 2010
    NJ
    Your boiler is designed to work with an indirect water tank. That might be the most cost effective solution. The WM Gold40 runs about $1,100. I use the Gold40 in my 4 bath house and have never run out of hot water.
  4. jadnashua
    Lots of good brands out there...I'm running a SuperStor Ultra.
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    We sell Super-Stor and Amtrol's Boiler Mate both of which are excellent choices but as Jim said, there are lots of them out there. Your temperature problem is either a failing tempering valve or the limit is set too low on the boiler. In either case though installing an indirect is the cost effective way to go and while you are at it have them install an outdoor temp re-set control and watch your oil bill drop dramatically.
  6. Gary in NJ
    Gary in NJ Member
    Apr 11, 2010
    NJ
    I read this recommendation and went and did some research. I installed a TACO ZVC404 just a few months ago and now I'm kicking myself for not getting the ZVC404-EXP. Adding the outdoor temp re-set control (TACO PC700) would have been so simple had I done this.
    I guess I can always put the ZVC404 on ****.
  7. DNYC
    DNYC New Member
    Jan 15, 2012
    NYC
    Thank you for all the suggestions. I think I'm gonna go with WM Aqua Plus 55 tank. Any suggestions as to how much this job might cost? Which additional accessories will I need with the install?
    Tom... I don't think its a failing tempering valve, as the boiler is year and a half old and the temperature is set at nearly 200 degrees F. I think Gary is right, indirect has to be installed with these systems, because the boiler coil capacity is low.
Similar Threads: WTGO-4 Boiler
Boiler Forum Boiler firing without call for heat on cold start Yesterday at 6:17 PM
Boiler Forum Weil McClain cga6pidn boiler Mar 17, 2017
Boiler Forum An American Standard Gas boiler Mar 13, 2017
Boiler Forum Boiler slowly fills Mar 7, 2017
Boiler Forum Should I replace ~70-year-old boiler? Mar 5, 2017
