WTB: vertical float with about 10" travel OR double float
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by ct-esq, Apr 24, 2009.
  1. ct-esq
    ct-esq New Member
    Dec 29, 2008
    I have a submersible pump and, after researching on this site, determined that I have been pumping out groundwater because the pump's integrated float switch is too short.
    I could probably put the pump on a brick to raise it up, but i've determined that the vertical float is best (i'm open to suggestions) but I can't find one with about 10" of travel. i want to pump out the basin, but only from the top.
    any suggestions? the sjm rombus has only 6.5 of travel.
    i'm not sure a double float would work well, but i can get turbulence in the basin from the pour in. and i'm afraid that the diameter of the basin is too small for the double float. 18" or so.
    i live in CT so no mercury switches.
    thanks in advance
  2. adam12
    adam12 Guest
    I am also looking for this from a long time.I really need this for my work.Thank you for sharing with us.
  4. ballvalve
    Dec 28, 2009
    northfork, california
    Nothing like an old brick or flat rock to solve a problem cheap. Keep it simple.
  5. bubb1957
    bubb1957 New Member
    Jan 9, 2007
    Banker
    Northern Ohio
    Do a search on Stevens Pumps..the S5310, S5710, and S5010 all have a 12" start and 3/12" stop, which gives you 8.5 inches difference. They have the pressure diaphragm switches, which some do not care for, but have been very reliable for me so far.
    http://www.stevenspump.com/sump-pumps.asp
Similar Threads: vertical float
Pumps and Tanks Well Forum & Blog. Water is life. Sta rite 1hp vertical deep well pumping but not building pressure. Jan 9, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Aquavar spd vertical pump Mar 21, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Zoeller m98 with an SJE vertical master switch....can it work? Dec 28, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Changing a vertical pump to a horizontal pump? Oct 13, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Mounting a Vertical Pressure Tank Horizontally. Jul 18, 2013
